ankit_cd
Calculating column values based on two columns and problem in fetching last row's calculation
A newbie to Power BI here. I am facing a calculation problem and not sure where I am going wrong. I am trying to create a new column in a separate table where the idea is to calculate sum (total cost) for a particular 'year' and a particular 'type of cost'.
For example, from above table, I want to generate a single value of cost (Approved in Tariff Order) for a single year (2010) and a single type of cost (fixed). Currently I have input the following formula and it gives me the accurate sum but only for (n-1) years. The calculation for last year is somehow not being generated
Fixed Costs  =
    CALCULATE(
        SUM(ARR_Approved[Approved in Tariff Order]),
        FILTER(ARR_Approved,ARR_Approved[Year]=APPC_Calculated[Year]),
        FILTER(ARR_Approved,ARR_Approved[Type of Cost]="Fixed")
See the output column generated in Power BI as below:
Appreciate all the help I can get here. Thank you 🙂
Hi @ankit_cd ,
Since you did not give a specific table, I had to create my own table for testing according to your description, please point out if there are any problems.
Please try below steps:
1. Below is my test table
Table1:
Table2:
2. In "Table2", add a new column with below dax formula
Total Cost =
VAR cur_year = Table2[Year]
VAR type_cost = "Fixed"
VAR tmp =
    FILTER (
        ALL ( Table1 ),
        Table1[Type of cost] = type_cost
            && YEAR ( Table1[Year] ) = cur_year
    SUMX ( tmp, [Cost] )
Please refer the attached .pbix file.
Best regards,
Community Support Team_ Binbin Yu
Hi @ankit_cd ,
Table1:
Table2:
Total Cost =
VAR tmp =
    FILTER (
        ALL ( Table1 ),
Best regards,
