RosG's avatar
RosG
11 months ago
Setting up a connection using a Virtual Network Data Gateway to an Azure SQL Database
I am trying to connect our PowerBI Service to an Azure SQL Server database.   I can connect the semantic model for a Report using Cloud connections and I have managed to set up a virtual network da...
    11 months ago
    Hi RosG ,
    The behavior you’re seeing is expected with the current VNet Data Gateway. The gateway doesn’t support Azure AD / Entra (OAuth) authentication for SQL Server, which is why your Entra MFA login works fine in SSMS but not through the gateway. SSMS supports modern authentication, whereas the VNet gateway can only connect to SQL Server using a SQL username and password. Because of that, Entra MFA succeeds in SSMS, fails through the gateway, and SQL authentication is the only method that works when using the VNet gateway.
    For reference, here are the Microsoft docs:
    VNet Data Gateway
    Use virtual network data gateway and data sources in Power BI | Microsoft Learn
    Azure SQL – Entra Authentication Overview (explains why SSMS works)
    https://learn.microsoft.com/en-us/azure/azure-sql/database/authentication-aad-overview
    If you require Entra-based authentication, the supported alternative is to use Managed VNet / Dataflows Gen2, which do support Entra ID and Managed Identity, unlike the VNet Data Gateway.
