Implement RLS in Power BI Using Application-Level Authentication
- 1 year ago
Hi ribisht
To implement RLS with application-level authentication (not using Microsoft user accounts), you should use Power BI embedding for service principals. First, assign RLS roles to the dataset in Power BI Desktop and publish it. Then, when generating the embed token in your application, pass the appropriate username as an effective identity in the token request. Power BI will apply RLS based on that username. This way, your app controls what data the user sees using its own authentication logic, while Power BI enforces RLS behind the scenes. No manual pivot or shared drives are needed once setup is complete.
Hi ribisht
