AI -generated support for Power BI technical problems
Has anyone noticed that responses from Power BI technical support are now generated by an A/I?
I notice this primarily on the NON-technical side of things, like if I ask why customers aren't given visibility to monitor capacity issues ("carry forward"), then the AI starts to respond with 100% meaningless language, eg.
As for your requests to see the latest carry-forward graphs, I do not have any information on that
The only way I could see a real person responding in that manner is if they are pretending to be a robot, or are extremely passive-aggressive. It is more likely that this is copy/pasted into an email from an A/I.
It was bad enough when professional support was outsourced to peers/clients who are external to Microsoft. But if support is being outsourced to an A/I then the quality will get rapidly worse. I'd guess the satisfaction rating won't matter anymore at the end of these cases either...
I ended up closing the case with a full satisfaction rating. The team, under ops manager N.P., is helpful and I rarely have any issue.However it is a bit concerning to wait a day or two for an answer to a technical question, only to get an AI-generated response.
I think it is important for the AI-generated portions of these responses to be properly annotated. That would allow customers to disregard those portions when submitting a satisfaction rating at the end of a support case.
I also think it is inappropriate for an AI to be responsible for certain portions of the the email, like the greeting at the start. Nobody wants to hear well-wishes from a bot. 😉
- AnonymousNot applicable
Hi dbeavon3 ,
We understand your concerns about Capacity Issues and Carry Forward issues, as well as your dissatisfaction with some technical support responses.
Additionally, we will investigate further into what you're saying and get back to the appropriate department, and you can provide the ticket ID of the issue you're experiencing.
If you are sensitive to personal privacy, you can also send me the ticket ID through community direct messages.
Wisdom Wu
- dbeavon3
Memorable Member
