Anonymous's avatar
4 years ago
power query split column by variable positions
Hi Community
I need to split Column1 based on variable postions from Custom.1  column. Same postion values stored as a list in Custom.3 column
I have tried using the list as an argument in  Splitter.SplitTextByPositions but it didn't work
Thanks in advance
Column1Custom.1
A B C0;2;4
4 5 60;2;4
A       B       C0;8;16
1       2       30;8;16
A  B    C0;3;8
11 22   330;3;8
  • Use below formula in a custom column
    = Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1])
    See the working here - Open a blank query - Home - Advanced Editor - Remove everything from there and paste the below code to test
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclRwUnBW0lEysDayNlGK1YlWMlEwVTBDEUGosbA2NAMLGSoYKRijCiFUGVtbQBQBVQGVGaMIOjo51xgaGZuYQkWBVsQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Custom.1 = _t]),
        #"Added Custom" = Table.AddColumn(Source, "Custom", each Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1]))
        #"Added Custom"
  • Vijay_A_Verma's avatar
    Vijay_A_Verma
    Icon for Most Valuable Professional rankMost Valuable Professional
        #"Added Custom"
      Thanks, it worked on my data but not from your Source, may be because it removed some blanks
      However, I modified it to CSV rather than JSON as below
      Thanks again
          Source = Csv.Document(
      "Column1,Custom.1
      A B C,0;2;4
      4 5 6,0;2;4
      A       B       C,0;8;16
      1       2       3,0;8;16
      A  B    C,0;3;8
      11 22   33,0;3;8",2,","),
          #"Promoted Headers" = Table.PromoteHeaders(Source, [PromoteAllScalars=true]),
          #"Added Custom" = Table.AddColumn(#"Promoted Headers", "Custom", each Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1])),
          #"Extracted Values" = Table.TransformColumns(#"Added Custom", {"Custom", each Text.Combine(List.Transform(_, Text.From), ":"), type text})
          #"Extracted Values"
