4 years agoNot applicable
power query split column by variable positions
Hi Community I need to split Column1 based on variable postions from Custom.1 column. Same postion values stored as a list in Custom.3 column I have tried using the list as an argument in Splitt...
- 4 years ago
Use below formula in a custom column
= Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1])See the working here - Open a blank query - Home - Advanced Editor - Remove everything from there and paste the below code to test
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WclRwUnBW0lEysDayNlGK1YlWMlEwVTBDEUGosbA2NAMLGSoYKRijCiFUGVtbQBQBVQGVGaMIOjo51xgaGZuYQkWBVsQCAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Custom.1 = _t]), #"Added Custom" = Table.AddColumn(Source, "Custom", each Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1])) in #"Added Custom"
Vijay_A_Verma
Most Valuable Professional
4 years agoUse below formula in a custom column
#"Added Custom"
Thanks, it worked on my data but not from your Source, may be because it removed some blanks
However, I modified it to CSV rather than JSON as below
Thanks again
Source = Csv.Document(
"Column1,Custom.1
A B C,0;2;4
4 5 6,0;2;4
A B C,0;8;16
1 2 3,0;8;16
A B C,0;3;8
11 22 33,0;3;8",2,","),
#"Promoted Headers" = Table.PromoteHeaders(Source, [PromoteAllScalars=true]),
#"Added Custom" = Table.AddColumn(#"Promoted Headers", "Custom", each Splitter.SplitTextByPositions(List.Transform(Text.Split([Custom.1],";"),each Number.From(_)))([Column1])),
#"Extracted Values" = Table.TransformColumns(#"Added Custom", {"Custom", each Text.Combine(List.Transform(_, Text.From), ":"), type text})
#"Extracted Values"
