Anonymous's avatar
5 years ago
Power query if statement help
Can someone please help me with the error on the attached picture? It seems as though I'm missing something simple, but can seem to be able to get the syntax right.
  • Anonymous , you have " sign on wrong place (in front of field name).
    "[MRP Type]="ND" then ...
    it should be
    Nemanja Andic
  • smpa01's avatar
    smpa01
    Anonymouscan you try it like this
    if ([Index]=1 and [val]<>null) then 1 else if ([Index]>1 and [val]<>null) then 2 else 0
  • nandic's avatar
    nandic
    Icon for Resident Rockstar rankResident Rockstar
    it should be
    Nemanja Andic
      That was it! Can't believe I didn't catch that. Thank you!!
