SaberSuM's avatar
SaberSuM
2 years ago
Power Query Help
I have combined multiple excel files using power query that resulted in this.
I have also merged another table on top of the current one, which requires me to split some employees' pay for that period. For example, employee B needs to split his cost to Cost Centre C & D by 50%, and employee C needs to split his cost across cost centre D & E.
Sample Data
Account CodeAccount NameAmountCost CentreStaffBCDE
446Salary1000AEmployee A
447Annual Leave100AEmployee A
449Superannuation100AEmployee A
446Salary2000BEmployee B 10001000
447Annual Leave200BEmployee B 100100
449Superannuation100BEmployee B 5050
446Salary2500CEmployee C  2000500
447Annual Leave100CEmployee C  8020
449Superannuation100CEmployee C  8020
Is there anyway I can transform the table and give me the result by cost centre, account code, and name without duplicating.
Desired Output:
Thank you in advance
*Edit: added sample data
    2 years ago
    Thanks for the solutions ManuelBolz  and dufoq3  provided, and i want to offer some more informationf for user to refer to.
    hello SaberSuM , you can create a blank query and put the following code to advanced editor .
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjExU9JRCk7MSSyqBDIMDQwMgJQjELvmFuTkV6amKoA4Cig4Vgek0RykMC+vNDFHwSc1sSwVop1Y3ZYga0sLUosSQUaUZObnkaYfxdlGEGc7IWt0gmqAeglK4XG8EV4z4CQRHsBqhqkBjMDuBVOwVmdkrc5I/oZ6EaSKQPDjNMLCAGwOYfcTNiEWAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Account Code" = _t, #"Account Name" = _t, Amount = _t, #"Cost Centre" = _t, Staff = _t, B = _t, C = _t, D = _t, E = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Account Code", Int64.Type}, {"Account Name", type text}, {"Amount", Int64.Type}, {"Cost Centre", type text}, {"Staff", type text}, {"B", Int64.Type}, {"C", Int64.Type}, {"D", Int64.Type}, {"E", Int64.Type}}),
        #"Replaced Value" = Table.ReplaceValue(#"Changed Type",null,0,Replacer.ReplaceValue,{"B", "C", "D", "E"}),
        #"Added Custom" = Table.AddColumn(#"Replaced Value", "A", each if [Cost Centre] = "A" then [Amount] else 0),
        #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Cost Centre", "Amount"}),
        #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Removed Columns", {"Staff", "Account Name", "Account Code"}, "Attribute", "Value"),
        #"Grouped Rows" = Table.Group(#"Unpivoted Other Columns", {"Account Code", "Account Name", "Attribute"}, {{"Sum", each List.Sum([Value]), type number}}),
        #"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Attribute", Order.Ascending}})
        #"Sorted Rows"
    Output
    Best Regards!
    Yolo Zhu
  • dufoq3's avatar
    dufoq3
    Hi, last (3rd) table shoud be the output? If yes, provide sample data in usable format (not as a screenshot please).
    • SaberSuM's avatar
      SaberSuM
      Correct, 3rd table is the output i am looking for.
      Sample Data
            #"Sorted Rows"
        Output
        Best Regards!
        Yolo Zhu
  • ManuelBolz's avatar
    ManuelBolz
    Icon for Responsive Resident rankResponsive Resident
    Hallo SaberSuM,
    i'm not sure if I understood your question correctly. But maybe the following code will help you.
        Source = [YOUR DATASOURCE],
        Datatype = Table.TransformColumnTypes(Source ,{{"Cost Centre", type text}, {"Account Code", Int64.Type}, {"Account Name", type text}, {"Debit", Int64.Type}}),
        Group = Table.Group(Datatype, {"Cost Centre"}, {{"Debit", each List.Sum([Debit]), type nullable number}, {"Account Code", each Table.RowCount(_), Int64.Type}})
        Group
    Did I answer your question? Please, mark my post as a solution!
  • SaberSuM's avatar
    SaberSuM
    Sample Data
