SaberSuM
2 years agoFrequent Visitor
Power Query Help
Hi, I have combined multiple excel files using power query that resulted in this. I have also merged another table on top of the current one, which requires me to split some employees' pay fo...
- Anonymous2 years ago
Thanks for the solutions ManuelBolz and dufoq3 provided, and i want to offer some more informationf for user to refer to.
hello SaberSuM , you can create a blank query and put the following code to advanced editor .
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMjExU9JRCk7MSSyqBDIMDQwMgJQjELvmFuTkV6amKoA4Cig4Vgek0RykMC+vNDFHwSc1sSwVop1Y3ZYga0sLUosSQUaUZObnkaYfxdlGEGc7IWt0gmqAeglK4XG8EV4z4CQRHsBqhqkBjMDuBVOwVmdkrc5I/oZ6EaSKQPDjNMLCAGwOYfcTNiEWAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Account Code" = _t, #"Account Name" = _t, Amount = _t, #"Cost Centre" = _t, Staff = _t, B = _t, C = _t, D = _t, E = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Account Code", Int64.Type}, {"Account Name", type text}, {"Amount", Int64.Type}, {"Cost Centre", type text}, {"Staff", type text}, {"B", Int64.Type}, {"C", Int64.Type}, {"D", Int64.Type}, {"E", Int64.Type}}), #"Replaced Value" = Table.ReplaceValue(#"Changed Type",null,0,Replacer.ReplaceValue,{"B", "C", "D", "E"}), #"Added Custom" = Table.AddColumn(#"Replaced Value", "A", each if [Cost Centre] = "A" then [Amount] else 0), #"Removed Columns" = Table.RemoveColumns(#"Added Custom",{"Cost Centre", "Amount"}), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Removed Columns", {"Staff", "Account Name", "Account Code"}, "Attribute", "Value"), #"Grouped Rows" = Table.Group(#"Unpivoted Other Columns", {"Account Code", "Account Name", "Attribute"}, {{"Sum", each List.Sum([Value]), type number}}), #"Sorted Rows" = Table.Sort(#"Grouped Rows",{{"Attribute", Order.Ascending}}) in #"Sorted Rows"Output
Best Regards!
Yolo Zhu
SaberSuM
Correct, 3rd table is the output i am looking for.
Sample Data
| Account Code | Account Name | Amount | Cost Centre | Staff | B | C | D | E |
| 446 | Salary | 1000 | A | Employee A | ||||
| 447 | Annual Leave | 100 | A | Employee A | ||||
| 449 | Superannuation | 100 | A | Employee A | ||||
| 446 | Salary | 2000 | B | Employee B | 1000 | 1000 | ||
| 447 | Annual Leave | 200 | B | Employee B | 100 | 100 | ||
| 449 | Superannuation | 100 | B | Employee B | 50 | 50 | ||
| 446 | Salary | 2500 | C | Employee C | 2000 | 500 | ||
| 447 | Annual Leave | 100 | C | Employee C | 80 | 20 | ||
| 449 | Superannuation | 100 | C | Employee C | 80 | 20 |
