andershh's avatar
andershh
Icon for Advocate I rankAdvocate I
10 years ago
Power BI Web Refresh issue: Expression.Error
Hi everyone,
When trying to refresh a dataset and report on the PowerBI website I get this error:
Something went wrong.
Cannot connect to the mashup data source. See error details for more information.
Please try again later or contact support. If you contact support, please provide these details. Underlying error code -2147467259 Underlying error message The key didn't match any rows in the table DM_ErrorDetailNameCode_UnderlyingHResult -2147467259 Microsoft.Data.Mashup.ValueError.Key [Schema = "DDKPROD", Item = "COUNTMARKETINGSTATUS"] Microsoft.Data.Mashup.ValueError.Reason Expression.Error Cluster URI WABI-NORTH-EUROPE-redirect.analysis.windows.net Activity ID 07ba0aeb-19ce-a77b-4b16-102b20252f12 Request ID de37e926-c2c7-1dfd-8592-e83ef3f79603 Time 2016-10-04 10:01:11Z
It is worth noting that I have no issue in accessing/refreshing the data when I open the report in Power BI desktop. The issue is when I upload the PowerBI desktop report to the PowerBI website and then from there tries to refresh the report/data. The table in question is called COUNTMARKETINGSTATUS, but the PowerBI website has had no problem in accessing it before now.
I have tried the following:
But the issue persists.
Do any of you have any suggestions as to what I can try to do or to what might be causing this issue?
Many thanks beforehand!
    10 years ago
    Hi andershh,
    What is your data source and have you made any changes in the COUNTMARKETINGSTATUS table?
    I would recommend you check that if your account that used to connect to the data source has sufficient permissions on this COUNTMARKETINGSTATUS table. If there is no issue with permission, please delete the data source under gateway and re-create the data source, then check if you can refresh the dataset successfully.
    Moreover, please make sure that the connection string parameters of the data source under gateway are same as that in Power BI Desktop.
    Lydia Zhang
    Hi andershh,
    Lydia Zhang
