andershh's avatar
andershh
Icon for Advocate I rankAdvocate I
10 years ago
Power BI Web Refresh issue: Expression.Error
Hi everyone,   When trying to refresh a dataset and report on the PowerBI website I get this error:   Something went wrong. Cannot connect to the mashup data source. See error details for more in...
    10 years ago
    Hi andershh,
    What is your data source and have you made any changes in the COUNTMARKETINGSTATUS table?
    I would recommend you check that if your account that used to connect to the data source has sufficient permissions on this COUNTMARKETINGSTATUS table. If there is no issue with permission, please delete the data source under gateway and re-create the data source, then check if you can refresh the dataset successfully.
    Moreover, please make sure that the connection string parameters of the data source under gateway are same as that in Power BI Desktop.
    Lydia Zhang
