I need help with using Power Query
- 1 year ago
Hi E12345, you need a combination of transpose/pivot/filldown to achieve what you are trying to do
Step 1: Your starting point should look like this ideally => years not in the headers, so we can easily use Transpose + Fill Down in the next steps:Step 2: Click on Column1 and apply Transform > Transpose. This will give you a new Column1 with one row for each year + a blank row below it. Use Transform > Replace Value if the empty rows (2, 4, 6 and 😎 are not null but blank (= look empty)
Step 3: Select Column1 and apply Transform > Fill > Down to fill the year-values into your null-rows:
Step 4: Select Column1 + Column2 and apply Transform > Unpivot Columns > Unpivot other Columns:
Step 5: Now Select Column2 (the one with the the values Course and Completions) and apply Transform > Pivot Column. Set the "Values Column" to "Value" (the one with Course A, 34 etc) and open the Advanced options to select "Don't Aggregate"
Step 6: Rename the Columns as needed, delete the extra column "Attribute" and adjust the datatypes as needed:
I hope that helps!
Quelle = Excel.CurrentWorkbook(){[Name="Tabelle1"]}[Content],
HeaderHoch = Table.PromoteHeaders(Quelle, [PromoteAllScalars=true]),
Topics = Table.ColumnNames(Quelle),
#"Sortierte Elemente" = List.Sort(Topics,Order.Ascending),
TNSpalten = List.Skip(#"Sortierte Elemente",List.Count(#"Sortierte Elemente")/2),
Jahre = {Number.From(Topics{0})..Number.From(Topics{List.Count(Topics)-2})},
AnzK =List.Count(HeaderHoch[Kurs])-1,
AnzJ = List.Count(Jahre)-1,
Ausgabe =
List.Generate
() => [Kurs = 0, Jahr = 0],
each [Jahr] <= AnzJ ,
each
Kurs = if [Kurs] < AnzK then [Kurs] + 1 else 0,
Jahr = if [Kurs] = AnzK then [Jahr] + 1 else [Jahr]
each [
Jahr = Jahre{[Jahr]} ,
Kurs = Record.Field(Quelle{[Kurs]+1}, Text.From(Jahre{[Jahr]})),
Teilnehmer = Record.Field(Quelle{[Kurs]+1}, TNSpalten{[Jahr]})
// Record.Field(Quelle{[Kurs]+1}, TNSpalten{[Kurs]})
NewTopics ={"Jahr","Kurs","Teilnehmer"},
#"In Tabelle konvertiert" = Table.FromList(Ausgabe, Splitter.SplitByNothing(), null, null, ExtraValues.Error),
#"Erweiterte Column1" = Table.ExpandRecordColumn(#"In Tabelle konvertiert", "Column1", NewTopics, NewTopics)
