I need help with using Power Query
- 1 year ago
Hi E12345, you need a combination of transpose/pivot/filldown to achieve what you are trying to do
Step 1: Your starting point should look like this ideally => years not in the headers, so we can easily use Transpose + Fill Down in the next steps:Step 2: Click on Column1 and apply Transform > Transpose. This will give you a new Column1 with one row for each year + a blank row below it. Use Transform > Replace Value if the empty rows (2, 4, 6 and 😎 are not null but blank (= look empty)
Step 3: Select Column1 and apply Transform > Fill > Down to fill the year-values into your null-rows:
Step 4: Select Column1 + Column2 and apply Transform > Unpivot Columns > Unpivot other Columns:
Step 5: Now Select Column2 (the one with the the values Course and Completions) and apply Transform > Pivot Column. Set the "Values Column" to "Value" (the one with Course A, 34 etc) and open the Advanced options to select "Don't Aggregate"
Step 6: Rename the Columns as needed, delete the extra column "Attribute" and adjust the datatypes as needed:
I hope that helps!
Here you go. All through the UI. No manual M coding needed.
Source = Excel.CurrentWorkbook(){[Name="myData"]}[Content],
#"Transposed Table" = Table.Transpose(Source),
#"Filled Down" = Table.FillDown(#"Transposed Table",{"Column1"}),
#"Merged Columns" = Table.CombineColumns(Table.TransformColumnTypes(#"Filled Down", {{"Column1", type text}}, "en-001"),{"Column1", "Column2"},Combiner.CombineTextByDelimiter(":", QuoteStyle.None),"Header"),
#"Transposed Table1" = Table.Transpose(#"Merged Columns"),
#"Promoted Headers" = Table.PromoteHeaders(#"Transposed Table1", [PromoteAllScalars=true]),
#"Added Index" = Table.AddIndexColumn(#"Promoted Headers", "Index", 0, 1, Int64.Type),
#"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Added Index", {"Index"}, "Attribute", "Value"),
#"Split Column by Delimiter" = Table.SplitColumn(#"Unpivoted Other Columns", "Attribute", Splitter.SplitTextByDelimiter(":", QuoteStyle.Csv), {"Attribute.1", "Attribute.2"}),
#"Pivoted Column" = Table.Pivot(#"Split Column by Delimiter", List.Distinct(#"Split Column by Delimiter"[Attribute.2]), "Attribute.2", "Value"),
#"Removed Columns" = Table.RemoveColumns(#"Pivoted Column",{"Index"}),
#"Renamed Columns" = Table.RenameColumns(#"Removed Columns",{{"Attribute.1", "Year"}})
#"Renamed Columns"
This will take the grey data (named range "myData") to the green table.
I cannot recreate it... My table looks weird when I merge. I will try again later.
UPDATE: I was able to recreate! THANK YOU SO MUCH!!!! This worked perfectly!
