I need help with using Power Query
- 1 year ago
Hi E12345, you need a combination of transpose/pivot/filldown to achieve what you are trying to do
Step 1: Your starting point should look like this ideally => years not in the headers, so we can easily use Transpose + Fill Down in the next steps:Step 2: Click on Column1 and apply Transform > Transpose. This will give you a new Column1 with one row for each year + a blank row below it. Use Transform > Replace Value if the empty rows (2, 4, 6 and 😎 are not null but blank (= look empty)
Step 3: Select Column1 and apply Transform > Fill > Down to fill the year-values into your null-rows:
Step 4: Select Column1 + Column2 and apply Transform > Unpivot Columns > Unpivot other Columns:
Step 5: Now Select Column2 (the one with the the values Course and Completions) and apply Transform > Pivot Column. Set the "Values Column" to "Value" (the one with Course A, 34 etc) and open the Advanced options to select "Don't Aggregate"
Step 6: Rename the Columns as needed, delete the extra column "Attribute" and adjust the datatypes as needed:
I hope that helps!
I hope that helps!
- E1234511 months ago
Resolver II
Thank you so much!!! I followed your steps and it worked!
