I need help with using Power Query
- 1 year ago
Hi E12345, you need a combination of transpose/pivot/filldown to achieve what you are trying to do
Step 1: Your starting point should look like this ideally => years not in the headers, so we can easily use Transpose + Fill Down in the next steps:Step 2: Click on Column1 and apply Transform > Transpose. This will give you a new Column1 with one row for each year + a blank row below it. Use Transform > Replace Value if the empty rows (2, 4, 6 and 😎 are not null but blank (= look empty)
Step 3: Select Column1 and apply Transform > Fill > Down to fill the year-values into your null-rows:
Step 4: Select Column1 + Column2 and apply Transform > Unpivot Columns > Unpivot other Columns:
Step 5: Now Select Column2 (the one with the the values Course and Completions) and apply Transform > Pivot Column. Set the "Values Column" to "Value" (the one with Course A, 34 etc) and open the Advanced options to select "Don't Aggregate"
Step 6: Rename the Columns as needed, delete the extra column "Attribute" and adjust the datatypes as needed:
I hope that helps!
Input data
Output results
Please find the code
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("pY69DsIwDIRfpfLcIXXi/owliAEeIcrYAQmaipb3x+6QvxXJw33n09nOASokaIGHlYlKR4WifOvAhu9nX5hseG+v5XiGdT/pbzu1NzOvtInBxrLssE+GBCjjxxnQeceFLUMpIjxOJVO1Rz6aVdjqyo3lMJRv1Vw2XNnps4Rwp1Qy7vLlWDGB9z8=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Column1 = _t, Column2 = _t, Column3 = _t, Column4 = _t, Column5 = _t, Column6 = _t, Column7 = _t, Column8 = _t]),
#"Kept top rows" = Table.FirstN(Source, 2),
#"Transposed table" = Table.Transpose(#"Kept top rows"),
#"Replaced value" = Table.ReplaceValue(#"Transposed table", "", null, Replacer.ReplaceValue, {"Column1"}),
#"Filled down" = List.Transform(Table.Split(Table.FillDown(#"Replaced value", {"Column1"}),2), each List.Transform(Table.ToColumns(_), each List.Distinct(_) )),
#"Removed top rows" = Table.Skip(Source, 2),
ColumsnAndYear = List.Split(Table.ToColumns(#"Removed top rows"),2),
#"Converted to table" = Table.FromList(ColumsnAndYear, Splitter.SplitByNothing()),
#"Added index" = Table.AddIndexColumn(#"Converted to table", "Index", 0, 1, Int64.Type),
#"Added custom" = Table.AddColumn(#"Added index", "Custom", each let
columns = #"Filled down"{[Index]}{1},
year = #"Filled down"{[Index]}{0}{0},
result = Table.AddColumn(Table.FromColumns([Column1],columns), "Year" ,each year)
result),
Custom = Table.Combine(#"Added custom"[Custom])
Custom
Connect on LinkedIn
