andyly85's avatar
andyly85
2 years ago
Help with coding conditional functions in power query
How do I code this in Power Query please?
If column 'Investment Vehicle Type' is Frontier Markets AND column Entity Relationship Name is 'TRP Fund of Funds', then Entity Relationship Name is 'Retirement Plan'.  Thanks in advance!
    2 years ago
    Hi andyly85 ,
    I can give you two ways:
    First solution:
    #"Replaced Value" = Table.ReplaceValue(
            #"Changed Type",
            each if [Investment Vehicle Type] = "Frontier Markets" and [Entity Relationship Name] = "TRP Fund of Funds" then [Entity Relationship Name] else false,
            "Retirement Plan",
            Replacer.ReplaceValue,
            {"Entity Relationship Name"}
    Origin:
    Output:
    Second solution:
    Custom1 = Table.FromRecords(Table.TransformRows(#"Changed Type",(x) => Record.TransformFields(x,{"Entity Relationship Name", each if x[Investment Vehicle Type] = "Frontier Markets" and x[Entity Relationship Name] = "TRP Fund of Funds" then "Retirement Plan" else _})))
    Origin:
    Output:
    Here are the two whole M codes in the Advanced Editor:
    First one:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrE6WBXml2SkFoElISwsWg1x6cVuCcwcqMmxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Investment Vehicle Type" = _t, #"Entity Relationship Name" = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"Investment Vehicle Type", type text}, {"Entity Relationship Name", type text}}),
            #"Changed Type",
            "Retirement Plan",
        #"Replaced Value"
    Second one:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrE6WBXml2SkFoElISwStGJRGAsA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Investment Vehicle Type" = _t, #"Entity Relationship Name" = _t]),
        Custom1
    Dino Tao
  • Hi! Here is what I used in order to achieve the below:
    #"Added Custom" = Table.AddColumn(#"Changed Type", "Entity Relationship NEW", each if [Invest Veh Type] = "Frontier Markets" and [Entity Relationship Name] = "TRP Fund of Funds" then "Retirement Plan" else [Entity Relationship Name])
    Here is the entire M-Code I have:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrGxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Invest Veh Type" = _t, #"Entity Relationship Name" = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Invest Veh Type", type text}, {"Entity Relationship Name", type text}}),
    #"Added Custom"
    • andyly85's avatar
      andyly85
      Hi!  Is it possible to code it without adding a new column?  Thanks!
  • Use this formula
    = Table.ReplaceValue(Source, each [Investment Vehicle Type]="Frontier Markets " and  [Entity Relationship Name]="TRP Fund of Funds" ,"",(a,b,c)=> if b then "Retirement Plan" else a ,{"Entity Relationship"})
    Hi andyly85 ,
    First solution:
            #"Changed Type",
            "Retirement Plan",
    Origin:
    Output:
    Second solution:
    Origin:
    Output:
    First one:
            #"Changed Type",
            "Retirement Plan",
        #"Replaced Value"
    Second one:
        Custom1
    Dino Tao
