Help with coding conditional functions in power query
- Anonymous2 years ago
Hi andyly85 ,
I can give you two ways:
First solution:#"Replaced Value" = Table.ReplaceValue( #"Changed Type", each if [Investment Vehicle Type] = "Frontier Markets" and [Entity Relationship Name] = "TRP Fund of Funds" then [Entity Relationship Name] else false, "Retirement Plan", Replacer.ReplaceValue, {"Entity Relationship Name"} )Origin:
Output:
Second solution:Custom1 = Table.FromRecords(Table.TransformRows(#"Changed Type",(x) => Record.TransformFields(x,{"Entity Relationship Name", each if x[Investment Vehicle Type] = "Frontier Markets" and x[Entity Relationship Name] = "TRP Fund of Funds" then "Retirement Plan" else _})))Origin:
Output:
Here are the two whole M codes in the Advanced Editor:
First one:let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrE6WBXml2SkFoElISwsWg1x6cVuCcwcqMmxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Investment Vehicle Type" = _t, #"Entity Relationship Name" = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Investment Vehicle Type", type text}, {"Entity Relationship Name", type text}}), #"Replaced Value" = Table.ReplaceValue( #"Changed Type", each if [Investment Vehicle Type] = "Frontier Markets" and [Entity Relationship Name] = "TRP Fund of Funds" then [Entity Relationship Name] else false, "Retirement Plan", Replacer.ReplaceValue, {"Entity Relationship Name"} ) in #"Replaced Value"Second one:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrE6WBXml2SkFoElISwStGJRGAsA", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Investment Vehicle Type" = _t, #"Entity Relationship Name" = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Investment Vehicle Type", type text}, {"Entity Relationship Name", type text}}), Custom1 = Table.FromRecords(Table.TransformRows(#"Changed Type",(x) => Record.TransformFields(x,{"Entity Relationship Name", each if x[Investment Vehicle Type] = "Frontier Markets" and x[Entity Relationship Name] = "TRP Fund of Funds" then "Retirement Plan" else _}))) in Custom1
Dino Tao
Hi! Here is what I used in order to achieve the below:
#"Added Custom" = Table.AddColumn(#"Changed Type", "Entity Relationship NEW", each if [Invest Veh Type] = "Frontier Markets" and [Entity Relationship Name] = "TRP Fund of Funds" then "Retirement Plan" else [Entity Relationship Name])
Here is the entire M-Code I have:
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WcivKzyvJTC1S8E0syk4tKVbSUQoJClBwK81LUchPA9PFSrGxAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Invest Veh Type" = _t, #"Entity Relationship Name" = _t]),
#"Changed Type" = Table.TransformColumnTypes(Source,{{"Invest Veh Type", type text}, {"Entity Relationship Name", type text}}),
#"Added Custom"
Hi! Is it possible to code it without adding a new column? Thanks!
