Audi_B's avatar
Audi_B
10 years ago
Using Substring to modify column data....Is it possible in Power BI?
Hello all, I have one column in a list showing all accounts with a prefix on all account numbers of "00000". So each of these account numbers show like this: "00000123456789".
I know in typical SQL, I can use a simple:  substring([account_num], 6,9), but is there a way to modify this in Power BI using DAX, or any other solution to this?
Thank you!
-B
  • Audi_B
    Try this in the Query Editor
    Actually you want to select Last Characters
  • Sean's solution will work for M code.
    In DAX, you could create a new column with the following formula:
    If all account numbers are the same length:
    AcctNum = RIGHT([Account Number],9)
    If not:
    AcctNum = MID([Account Number,6,LEN([Account Number]) - 5)
    You may have to adjust start number and how many characters you are removing from what LEN returns, but general gist is there.
  • Greg_Deckler's avatar
    Greg_Deckler
    If not:
    • Audi_B's avatar
      Audi_B
      Thank you both for the solution. I ended up creating new column and it's working as needed.
      Thanks again for quick reply!
      -B
      • Sean's avatar
        Sean
        If you want to keep the original column - you can hit Duplicate Column first and then Rename and Transform the duplicate so you have access to both columns for reports.
        EDIT: You never actually permanently Transform your original data even if you don't duplicate the Column.
        You can go in the Query Settings => Applied Steps and just delete that step!
  • Sean's avatar
    Sean
    Audi_B
