Using Substring to modify column data....Is it possible in Power BI?
- 10 years ago
Sean's solution will work for M code.
In DAX, you could create a new column with the following formula:
If all account numbers are the same length:
AcctNum = RIGHT([Account Number],9)
If not:
AcctNum = MID([Account Number,6,LEN([Account Number]) - 5)
You may have to adjust start number and how many characters you are removing from what LEN returns, but general gist is there.
If not:
- Audi_B10 years agoFrequent Visitor
Thank you both for the solution. I ended up creating new column and it's working as needed.
Thanks again for quick reply!
-B
- Sean10 years ago
If you want to keep the original column - you can hit Duplicate Column first and then Rename and Transform the duplicate so you have access to both columns for reports.
EDIT: You never actually permanently Transform your original data even if you don't duplicate the Column.
You can go in the Query Settings => Applied Steps and just delete that step!
