SQL Code or Power Query for data massage
- 6 years ago
Generally you will have better performance the further up the chain that you push things. Think of it this way, if you implement the data cleanup in SQL you are pushing the work to the SQL box and thus using the server's resources to execute on the code versus with Power Query, a lot of the work is being done by the computer on which you are running Power BI. Generally going to be faster executing on a server which likely has better CPU/RAM than a computer. In addition, the query and cleanup is essentially happening locally so faster disk I/O. Plus, you are only pushing the relevant data across the wire (network) so that could very likely be much faster as well.
Again, these are generalities and your specific situation may be different.
Anonymous the way you want to look at this where business logic should reside. Think of it if you are going to use the same table in some other report and need switch/case condition, better to do it in sql so that every report using the same table has one layer of business logic. Hope this helps.
