Anonymous's avatar
7 years ago
Reference Table through Power BI - PLEASE HELP!
I am trying to build a relationship between two tables.  One of the tables was supposed to have unique values, to create a relationship.
Is there a way in PowerBI to take a column from a table, create a third table from the deisred column(the reference table) and distill the values down to a unique set of values?
    7 years ago
    Hi Anonymous
    You can easily do this in Power Query.
    Right click Original Table, select Reference , Remove the unwanted columns, select "Remove Duplicates", now you will have the column with unique values .
    You can use this table as Relationship / Bridge table as you needed.
    Raj
    Hi Anonymous
    Raj
      Thanks, one last question.  To create the relationships, I am concatenating two colums.  Since this is a function, I can't seem to remove the duplicates in Power Query.  Any thoughts?
      Thanks!
        You will still get that option. Right click on the customn column you have created , you will see Remove duplicates option.
        Raj
  • cb_ohio's avatar
    cb_ohio
    One quick and easy method would be to make a reference copy of one of the tables and group by the column you want distinct values for.  You can eliminate any of the other columns you don't want.
      cb_ohio
      Can you send me some screenshots or steps...not sure I know how to do this.
        Yes, you can do that way also, Both gives same result.
        Click on the column you created, Go to Transform Tab -> Click Group by , it will create 2 columns , one is the unique value of your column and another one is based on your selection ( ex: count). You can delete the extra column and keep the custom column.
        Raj
  • v-jiascu-msft's avatar
    v-jiascu-msft
    Hi Anonymous,
    A solution using DAX could be like below. Please give it a try.
    Table =
    FILTER (
        DISTINCT (
            SELECTCOLUMNS ( 'DimProduct', "key", CONCATENATE ( [BrandName], [ColorName] ) )
        ISBLANK ( [key] ) = FALSE ()
    Dale
      v-jiascu-msft
      What is the first step in creating a new table.  It is no longer in the "Modeling" tab?
      Can you also breakdown the components in the DAX starement so I understand the references and how to translate that to my dataset and how they apply?
      Thanks!
  • cb_ohio's avatar
    cb_ohio
    I first createsd a table "ORDERS"
    ORDERS
    Next, I right click on ORDERS and select "Reference"
    Reference Table
    Next I renamed the table to "INVENTORY" and grouped by "FRUIT"
    Result:
    v-jiascu-msft
    Hi Anonymous,
    Dale
