7 years agoNot applicable
Reference Table through Power BI - PLEASE HELP!
I am trying to build a relationship between two tables. One of the tables was supposed to have unique values, to create a relationship. Is there a way in PowerBI to take a column from a table, c...
- Anonymous7 years ago
Hi Anonymous
You can easily do this in Power Query.
Right click Original Table, select Reference , Remove the unwanted columns, select "Remove Duplicates", now you will have the column with unique values .
You can use this table as Relationship / Bridge table as you needed.
Raj
v-jiascu-msft
7 years agoHi Anonymous,
A solution using DAX could be like below. Please give it a try.
Table =
FILTER (
DISTINCT (
SELECTCOLUMNS ( 'DimProduct', "key", CONCATENATE ( [BrandName], [ColorName] ) )
ISBLANK ( [key] ) = FALSE ()
Dale
What is the first step in creating a new table. It is no longer in the "Modeling" tab?
Can you also breakdown the components in the DAX starement so I understand the references and how to translate that to my dataset and how they apply?
Thanks!
- cb_ohio7 years agoFrequent Visitor
On the "Home" tab "Enter Data"
- v-jiascu-msft7 years ago
Hi Anonymous,
Please refer to the snapshot and the comments on the code.
Table = FILTER ( //filter out blanks, for you want to establish relationship. DISTINCT ( //only keep unique values. SELECTCOLUMNS ( 'DimProduct', "key", CONCATENATE ( [BrandName], [ColorName] ) ) ), //concatenate two fileds as you mentioned. 'DimProduct' is a table while [BrandName] and [ColorName] are columns of 'DimPorduct'. ISBLANK ( [key] ) = FALSE () )Best Regards,
Dale
