Anonymous's avatar
3 years ago
Python Script not working power bi
I am trying to use python scripting on power bi. but i am getting an error while executing a script. I have installed Pandas and matplotlib libraries. How do i solve this issue?
  • Hi Anonymous
    I am not an expert in using phyton scripts in Power BI but since it says access denied is it possible that the ibraries are stored in a location which can only be accessed with some kind of admin rights on your machine?
    Did you check this site as well as the explained settings/actions?
    Run Python Scripts in Power BI Desktop - Power BI | Microsoft Learn
    Best regards
    Michael
    If this post helps, then please consider Accept it as the solution to help the other members find it more quickly. Appreciate your thumbs up!
    @ me in replies or I'll lose your thread.
  • Mikelytics's avatar
    Mikelytics
    Icon for Resident Rockstar rankResident Rockstar
    Hi Anonymous
    Best regards
    Michael
    Mikelytics
    Here is another artcile on medium about an ADO.net error with Phyton
    Fixing ADO.NET error trying to run Python Script in Power BI | by Luca Zavarella | Microsoft Azure | Medium
    Best regards
    Michael
    Thanks for the reply. I guess thats it.
