3 years agoNot applicable
Python Script not working power bi
Hi, I am trying to use python scripting on power bi. but i am getting an error while executing a script. I have installed Pandas and matplotlib libraries. How do i solve this issue?
- 3 years ago
Hi Anonymous
I am not an expert in using phyton scripts in Power BI but since it says access denied is it possible that the ibraries are stored in a location which can only be accessed with some kind of admin rights on your machine?
Did you check this site as well as the explained settings/actions?
Run Python Scripts in Power BI Desktop - Power BI | Microsoft Learn
Best regards
Michael
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly. Appreciate your thumbs up!
@ me in replies or I'll lose your thread.
Thanks for the reply. I guess thats it.
