5 years agoNot applicable
Problems with SUMX
Hi, i am trying to accumulate the results of the following measure: ind_rotacion = VAR rota_colab = SUM(Sheet1[ROTACION]) VAR totalcolaborador= COUNT(Sheet1[Contrato]) RETUR...
- Anonymous5 years ago
Hi Anonymous ,
Refer the formula.
Measure = SUMX(FILTER(ALLSELECTED(sheet1[Mes]),sheet1[Mes]<=MAX(sheet1[Mes])),[ind_rotacion])Best Regards,
Jay
Hi Anonymous ,
Refer the formula.
Jay
Thank you so much Jay, i've been looking for this answer quite some time now. it worked!! Would you please explain me the difference between filter by Sheet1 and filter by Sheet1[month]. It made a difference in the result
