Problems with SUMX
- Anonymous5 years ago
Hi Anonymous ,
Refer the formula.
Measure = SUMX(FILTER(ALLSELECTED(sheet1[Mes]),sheet1[Mes]<=MAX(sheet1[Mes])),[ind_rotacion])Best Regards,
Jay
Anonymous , Can you share sample data and sample output in table format? with based columns
try like
divide( SUMX(FILTER(ALLSELECTED(Sheet1),Sheet1[Mes]<=MAX(Sheet1[Mes])),Sheet1[ROTACION]) ,
COUNTX(FILTER(ALLSELECTED(Sheet1),Sheet1[Mes]<=MAX(Sheet1[Mes])),Sheet1[Contrato]))
- Anonymous5 years agoNot applicable
Thank you so much for the quick response. I tryed the DAX fuction and it gave me zero. I think in there we would be acumulating the number of employees that quit divided by the monthly count of the employees. But i need to acumulate the result of that division. Sadly i cannot share an exact data sample, but i made one.
Anio Mes cod_mes Contrato Nombre Identificacion ROTACION fecha_mensual 2021 1 20211 566687901 peter parker 111111111 0 1/01/2021 2021 2 20212 566687901 peter parker 111111111 0 1/02/2021 2021 3 20213 566687901 peter parker 111111111 0 1/03/2021 2021 4 20214 566687901 peter parker 111111111 0 1/04/2021 2021 5 20215 566687901 peter parker 111111111 0 1/05/2021 2021 6 20216 566687901 peter parker 111111111 1 1/06/2021 2021 1 20211 77889011 samantha jhonson 222222222 0 1/01/2021 2021 2 20212 77889011 samantha jhonson 222222222 0 1/02/2021 2021 3 20213 77889011 samantha jhonson 222222222 0 1/03/2021 2021 4 20214 77889011 samantha jhonson 222222222 0 1/04/2021 2021 5 20215 77889011 samantha jhonson 222222222 0 1/05/2021 2021 6 20216 77889011 samantha jhonson 222222222 0 1/06/2021 2021 1 20211 33300011 peter parker 333333333 0 1/01/2021 2021 2 20212 33300011 peter parker 333333333 1 1/02/2021 2021 1 20211 88888888 john doe 44444444 0 1/01/2021 2021 2 20212 88888888 john doe 44444444 0 1/02/2021 2021 3 20213 88888888 john doe 44444444 0 1/03/2021 2021 4 20214 88888888 john doe 44444444 0 1/04/2021 2021 5 20215 88888888 john doe 44444444 0 1/05/2021 2021 6 20216 88888888 john doe 44444444 0 1/06/2021 2021 1 20211 76514238 john doe 55555555 0 1/01/2021 2021 2 20212 76514238 john doe 55555555 0 1/02/2021 2021 3 20213 76514238 john doe 55555555 0 1/03/2021 2021 4 20214 76514238 john doe 55555555 0 1/04/2021 2021 5 20215 76514238 john doe 55555555 1 1/05/2021 this is kinda what i have the total of employees varies each month and i have a dummy column with a 1 in the month they rotated so i sum those ones and count the total of contracts and then i divide it getting the ind_rotation measure. In the report i created a table and added the month, the sum of the rotation, the count of the contracts and the ind_rotation measure and it gaves me the monthly indicator which i need to accumulate
I need another measure to acummulates the ind_rotation in order to add it to the table. also i need it to be this way cuz i need to filter by zone and management office
count of contracts sum of rotation ind_rotation acum ind_rotation 1277 15 1,17% 1,17% 1322 18 1,36% 2,54% 1332 24 1,80% 4,34% 1331 31 2,33% 6,67% 1363 21 1,54% 8,21% 1371 12 0,88% 9,08% Again, thank you so much for your help
Anio Mes cod_mes Contrato Nombre Identificacion ROTACION fecha_mensual 2021 1 20211 566687901 peter parker 111111111 0 1/01/2021 2021 2 20212 566687901 peter parker 111111111 0 1/02/2021 2021 3 20213 566687901 peter parker 111111111 0 1/03/2021 2021 4 20214 566687901 peter parker 111111111 0 1/04/2021 2021 5 20215 566687901 peter parker 111111111 0 1/05/2021 2021 6 20216 566687901 peter parker 111111111 1 1/06/2021 2021 1 20211 77889011 samantha jhonson 222222222 0 1/01/2021 2021 2 20212 77889011 samantha jhonson 222222222 0 1/02/2021 2021 3 20213 77889011 samantha jhonson 222222222 0 1/03/2021 2021 4 20214 77889011 samantha jhonson 222222222 0 1/04/2021 2021 5 20215 77889011 samantha jhonson 222222222 0 1/05/2021 2021 6 20216 77889011 samantha jhonson 222222222 0 1/06/2021 2021 1 20211 33300011 peter parker 333333333 0 1/01/2021 2021 2 20212 33300011 peter parker 333333333 1 1/02/2021 2021 1 20211 88888888 john doe 44444444 0 1/01/2021 2021 2 20212 88888888 john doe 44444444 0 1/02/2021 2021 3 20213 88888888 john doe 44444444 0 1/03/2021 2021 4 20214 88888888 john doe 44444444 0 1/04/2021 2021 5 20215 88888888 john doe 44444444 0 1/05/2021 2021 6 20216 88888888 john doe 44444444 0 1/06/2021 2021 1 20211 76514238 john doe 55555555 0 1/01/2021 2021 2 20212 76514238 john doe 55555555 0 1/02/2021 2021 3 20213 76514238 john doe 55555555 0 1/03/2021 2021 4 20214 76514238 john doe 55555555 0 1/04/2021 2021 5 20215 76514238 john doe 55555555 1 1/05/2021 this is kinda what i have the total of employees varies each month and i have a dummy column with a 1 in the month they rotated so i sum those ones and count the total of contracts and then i divide it getting the ind_rotation measure. In a table an add the month the sum of the rotation, the count of the contracts and the ind_rotation measure and it gaves me the monthly indicator which i need to accumulate
This would be the output table
count of contracts sum of rotation ind_rotation accum ind_rotation 1277 15 1,17% 1,17% 1322 18 1,36% 2,54% 1332 24 1,80% 4,34% 1331 31 2,33% 6,67% 1363 21 1,54% 8,21% 1371 12 0,88% 9,08%
