3 years agoNot applicable
Problems with Displaying Icons Using Conditional Formatting
Hi, community! Good morning. I'm currently experiencing an issue. I have a straightforward measure that should display icons according to the team's ranking. However, when I attempt to apply this me...
Hi Dhairya, thank you for your response.
Unfortunately, the information provided didn't offer much assistance. I was already familiar with how to add customized icons to Power BI, and that is not the issue at hand. The problem I'm facing is that Power BI is not displaying the built-in icons (Windows key + .). This problem started occurring suddenly, as I used to rely on this method for conditional formatting, but it is no longer functioning.
Best regards.
Dhairya
Solution Supplier
3 years agoThis Can be an issue on power bi updates, have you tried another way for conditional formatting using rules instead of measures?
