Problems with Displaying Icons Using Conditional Formatting
Hey Anonymous
please refer below video, in which they have given a detailed explanation for conditional formatting using custom icons.
https://www.youtube.com/watch?v=YDJQrmBs4Iw
If it help you please mark my solution as accepted!
Hi Dhairya, thank you for your response.
Unfortunately, the information provided didn't offer much assistance. I was already familiar with how to add customized icons to Power BI, and that is not the issue at hand. The problem I'm facing is that Power BI is not displaying the built-in icons (Windows key + .). This problem started occurring suddenly, as I used to rely on this method for conditional formatting, but it is no longer functioning.
Best regards.- Dhairya3 years ago
Solution Supplier
This Can be an issue on power bi updates, have you tried another way for conditional formatting using rules instead of measures?
