problem with sum values with dates
- 6 years ago
Hi Anonymous ,
We can create a measure and use it in visual filter to meet your requirement:
IsOneMoreDay = IF ( SELECTEDVALUE ( 'Table'[Date].[MonthNo] ) = MONTH ( CALCULATE ( MAX ( 'Table'[Date] ), FILTER ( ALLSELECTED ( 'Table' ), YEAR ( 'Table'[Date] ) = 2019 ) ) ) && SELECTEDVALUE ( 'Table'[Date].[Day] ) > DAY ( CALCULATE ( MAX ( 'Table'[Date] ), FILTER ( ALLSELECTED ( 'Table' ), YEAR ( 'Table'[Date] ) = 2019 ) ) ) + 1, -1, 1 )
If it doesn't meet your requirement, Please show the exact expected result based on the Tables that we have shared.
Best regards, - 6 years ago
Hi Anonymous ,
First of all, we suggest you to delete the shared link if it contain any confidential information or real data.
Please try to use the following measure , and the result should be following if we put the month column into the table visual:
IsOneMoreDay = VAR MaxDayOf2019 = MAXX ( FILTER ( SUMMARIZE ( ALLSELECTED ( 'Tabla' ), 'Tabla'[Fecha], "2019", [Vta_rtl19sd] ), [2019] + 0 <> 0 ), [Fecha] ) RETURN IF ( OR ( SELECTEDVALUE ( 'Tabla'[Fecha].[NroMes] ) > MONTH ( MaxDayOf2019 ), AND ( SELECTEDVALUE ( 'Tabla'[Fecha].[NroMes] ) = MONTH ( MaxDayOf2019 ), SELECTEDVALUE ( 'Tabla'[Fecha].[Día] ) > DAY ( MaxDayOf2019 ) + 1 ) ), -1, 1 )
Best regards,
It didn't work :(. vta_rtlsd19 = SUM (VIEW_GEGCOM_GTN_VTA_SUC_PRD_DIA [vta_rtl19]) / 1000000 vta_rtl18sd is the same but with the 2018 column, I originally have 1 sales column and I separated them to have them per year, I will upload a copy of my pbix so you can see it in more detail
Hi Anonymous ,
IsOneMoreDay =
VAR MaxDayOf2019 =
MAXX (
FILTER (
[2019] + 0 <> 0
[Fecha]
IF (
OR (
AND (
-1,
1
Best regards,
