problem with sum values with dates
- 6 years ago
Hi Anonymous ,
We can create a measure and use it in visual filter to meet your requirement:
IsOneMoreDay = IF ( SELECTEDVALUE ( 'Table'[Date].[MonthNo] ) = MONTH ( CALCULATE ( MAX ( 'Table'[Date] ), FILTER ( ALLSELECTED ( 'Table' ), YEAR ( 'Table'[Date] ) = 2019 ) ) ) && SELECTEDVALUE ( 'Table'[Date].[Day] ) > DAY ( CALCULATE ( MAX ( 'Table'[Date] ), FILTER ( ALLSELECTED ( 'Table' ), YEAR ( 'Table'[Date] ) = 2019 ) ) ) + 1, -1, 1 )
If it doesn't meet your requirement, Please show the exact expected result based on the Tables that we have shared.
Best regards, - 6 years ago
Hi Anonymous ,
First of all, we suggest you to delete the shared link if it contain any confidential information or real data.
Please try to use the following measure , and the result should be following if we put the month column into the table visual:
IsOneMoreDay = VAR MaxDayOf2019 = MAXX ( FILTER ( SUMMARIZE ( ALLSELECTED ( 'Tabla' ), 'Tabla'[Fecha], "2019", [Vta_rtl19sd] ), [2019] + 0 <> 0 ), [Fecha] ) RETURN IF ( OR ( SELECTEDVALUE ( 'Tabla'[Fecha].[NroMes] ) > MONTH ( MaxDayOf2019 ), AND ( SELECTEDVALUE ( 'Tabla'[Fecha].[NroMes] ) = MONTH ( MaxDayOf2019 ), SELECTEDVALUE ( 'Tabla'[Fecha].[Día] ) > DAY ( MaxDayOf2019 ) + 1 ) ), -1, 1 )
Best regards,
Hi Anonymous ,
IsOneMoreDay =
IF (
= MONTH (
> DAY (
) + 1,
-1,
1
Best regards,
Good day
Sorry for the holiday delay. I didn't have my equipment at hand. Use the measure you described but it didn't show me the expected result.
I need that at the maximum date of 2019 (Dec 25) I can make the sale of 2018 with one more day (Dec 26) to be able to compare with the equivalent days and that the other days are not displayed
- v-lid-msft6 years ago
Hi Anonymous ,
We apologise for that we end this topic too early. Could you please share the formula of Measure "IsOneMoreAfter" which have been modified so we can find the reason why it cannot work?
Best regards,- Anonymous6 years agoNot applicableIsOneMoreDay =IF (SELECTEDVALUE ( Tabla[Fecha].[NroMes] )= MONTH (CALCULATE (MAX ( Tabla[Fecha] );FILTER ( ALLSELECTED ( 'Tabla' ); YEAR ( 'Tabla'[Fecha] ) = 2019 )))&& SELECTEDVALUE ( 'Tabla'[Fecha].[Día] )> DAY (CALCULATE (MAX ( Tabla[Fecha] );FILTER ( ALLSELECTED ( 'Tabla' ); YEAR ( 'Tabla'[Fecha] ) = 2019 ))) + 1;-1;1)
I tried to change the year "2019" to "2020" but it didn't work either.- v-lid-msft6 years ago
Hi Anonymous ,
Could you please try to use the following measure in the visual filter if the [Vta_rtl19sd] is a measure?
IsOneMoreDay = VAR MaxDayOf2019 = FILTER ( SUMMARIZE ( ALLSELECTED ( 'Table' ); 'Table'[Fecha].[Mes]; 'Table'[Fecha].[Día]; "2019"; [Vta_rtl19sd] ); [2019] + 0 <> 0 ) VAR MaxMonth = MAXX ( MaxDayof2019; [Mes] ) VAR MaxDay = MAXX ( MaxDayof2019; [Día] ) RETURN IF ( SELECTEDVALUE ( Tabla[Fecha].[Mes] ) = MaxMonth && SELECTEDVALUE ( 'Tabla'[Fecha].[Día] ) > MaxDay + 1; -1; 1 )If it does not work, cloud you please try to share the formula of [Vta_rtl19sd] if it is a measure?
If the [Vta_rtl19sd] is a column of this table, please try to use the following measure:
IsOneMoreDay = VAR MaxDayOf2019 = FILTER ( SUMMARIZE ( ALLSELECTED ( 'Table' ); 'Table'[Fecha].[Mes]; 'Table'[Fecha].[Día]; "2019"; SUM ( 'Table'[Vta_rtl19sd] ) ); [2019] + 0 <> 0 ) VAR MaxMonth = MAXX ( MaxDayof2019; [Mes] ) VAR MaxDay = MAXX ( MaxDayof2019; [Día] ) RETURN IF ( SELECTEDVALUE ( Tabla[Fecha].[Mes] ) = MaxMonth && SELECTEDVALUE ( 'Tabla'[Fecha].[Día] ) > MaxDay + 1; -1; 1 )
Best regards,
