axata
9 years agoProblem with loading data into POWER BI DESKTOP
Hi, I am having trouble loading a large data set into Power BI desktop.The data source i have used is MongoDB. I am using the ODBC driver to load the data. It is taking too much time to load ...
9 years agoNot applicable
axata It is probably the memory on your machine that is the restriction. How large is the data as it sits in MongoDB?
- axata9 years ago
My Data which are stored in MongoDB is containing the almost 6 crore data in it. and the size of the file is 6.73 GB.
- prateekraina9 years ago
Memorable Member
- Anonymous9 years agoNot applicable
Also want to just check an easy missed variable too. Are you using 32bit or 64bit version of Power BI?
