Pooja1
9 years agoNew Member
Problem with Drill Down Choropleth
Hi , Unable to get appropriate shape files for using with Drill Down Choropleth plot, I want to drill down from U.S. state to city and ZIP code levels, but unable to figure out what should be...
v-huizhn-msft
9 years agoHi Pooja1,
What visual did you use in Power BI desktop? You use shape map? And you said you use same shape files provided with Power BI example, please share more details about which shape files did you use? There is a thread, I am not sure if it is helpful.
Angelia
- Pooja19 years agoNew Member
Hi Angelia,
Thanks for your response, I used "Drill Down Choropleth",
below is link for shape files I used:
https://uat.gramener.com/static/c3/US_adm1.json
https://uat.gramener.com/static/c3/US_adm2.json,
Pooja
