rcardenasbc
2 years agoFrequent Visitor
Problem with dax and matrix visual
I have a problem with the Matrix visual, and that is that the budget value is repeated in each line and that does not happen with current The dax of Actual is: Actual = var Value = SUM(Sap[Actual])...
- 2 years ago
Hi rcardenasbc
Repeated value likely is due to incorrect relationship with your master table and the budget table. Can you double check to make sure the relationship is corrected?
rcardenasbc
hnguy71
2 years agohi rcardenasbc ,
Your vendor/supplying plant and detail both needs to come from GLALL table. Since GLALL is a distinct/unique table using your SAP table as source, you should have both of those columns there as well.
Replace these two columns and your data should flow properly.
