Problem to use DATEDIFF function between two dates which located in two not directly related tables
Problem to use DATEDIFF function between two dates which located in two but not directly related tables.
Task: Stock.Registration_Date - Invoices.InvoiceDate
Formula: NeedDate= DATEDIFF([Registration_Date],RELATED(Invoices[InvoiceDate]),WEEK)
Err: The column 'Invoices[InvoiceDate]' either doesn't exist or doesn't have a relationship to any table available in the current context
Comments: There two tables "Stock" and "Invoice" - they are related through table in between "InvoiceLines".
Thank you
Given the relationship, you may use RELATEDTABLE Function.
MAXX ( RELATEDTABLE ( Invoices ), Invoices[InvoiceDate] )
- Phil_Seamark
- aadassFrequent Visitor
For now "Stock" table.. - where i am trying to create new Measure. (In the future this New Measure should be used in
report(Visualization)
but i mentioned those three tbls because tbl InvoiceLines is in between two Main tbls "Stock" and "Invoices"
I need one field from Stock and one from Invoices (they are not linked directly - but only through InvoiceLines )
tnx
Angelika
- v-chuncz-msft
