aadass
8 years agoFrequent Visitor
Problem to use DATEDIFF function between two dates which located in two not directly related tables
Problem to use DATEDIFF function between two dates which located in two but not directly related tables. Task: Stock.Registration_Date - Invoices.InvoiceDate Formula: NeedDate= DATEDIFF([R...
- 8 years ago
Given the relationship, you may use RELATEDTABLE Function.
MAXX ( RELATEDTABLE ( Invoices ), Invoices[InvoiceDate] )
Phil_Seamark
8 years ago- aadass8 years agoFrequent Visitor
For now "Stock" table.. - where i am trying to create new Measure. (In the future this New Measure should be used in
report(Visualization)
but i mentioned those three tbls because tbl InvoiceLines is in between two Main tbls "Stock" and "Invoices"
I need one field from Stock and one from Invoices (they are not linked directly - but only through InvoiceLines )
tnx
Angelika
- v-chuncz-msft8 years ago
Sam,
i think it solved my issue:
Weeks in stock = DATEDIFF([Registration_Date],MAXX(RELATEDTABLE(Invoices),Invoices[InvoiceDate]),WEEK)
I would never thought that MAXX can act as a little liason between "unrelated" tables
Thank you much
Angelika
