Power query help for adding conditional count column
Power Query help to calculate count column.
if Store is same and Brand and type is also same for all rows then count should be 1. (from below example Apple)
If store is same but two different combination of Brand and Type then count should be 2 and so on. (From below example Samsung)
Data
| Brand | Type | Store |
| Apple | Iphone | NYC |
| Samsung | S22 | NJ |
| Samsung | S21 | NJ |
Result
| Brand | Type | Store | Count |
| Apple | Iphone | NYC | 1 |
| Samsung | S22 | NJ | 2 |
| Samsung | S21 | NJ | 2 |
Hi PSB!
You can do the column in two steps. First you want to do the distinct count group by brand, then you can expand the result.
In the advanced editor, it should look like this:
#"Grouped Rows" = Table.Group(#"Changed Type", {"Brand"}, {{"Count", each Table.RowCount(Table.Distinct(_)), Int64.Type}, {"All", each _, type table [Brand=nullable text, Type=nullable text, Store=nullable text]}}),
#"Removed Columns" = Table.RemoveColumns(#"Grouped Rows",{"Brand"}),
#"Expanded All" = Table.ExpandTableColumn(#"Removed Columns", "All", {"Brand", "Type", "Store"}, {"Brand", "Type", "Store"})"All.Type", "All.Store"})Cheers!
- RicardoncostaRegular Visitor
Hi PSB!
- PSB
Helper III
amitchandak Could you please help resolving this either by DAX or Power Query?
- amitchandak
