PSB
Helper III
3 years agoPower query help for adding conditional count column
Greg_Deckler Power Query help to calculate count column. if Store is same and Brand and type is also same for all rows then count should be 1. (from below example Apple) If store is same but two ...
- 3 years ago
Hi PSB!
You can do the column in two steps. First you want to do the distinct count group by brand, then you can expand the result.
In the advanced editor, it should look like this:
#"Grouped Rows" = Table.Group(#"Changed Type", {"Brand"}, {{"Count", each Table.RowCount(Table.Distinct(_)), Int64.Type}, {"All", each _, type table [Brand=nullable text, Type=nullable text, Store=nullable text]}}),
#"Removed Columns" = Table.RemoveColumns(#"Grouped Rows",{"Brand"}),
#"Expanded All" = Table.ExpandTableColumn(#"Removed Columns", "All", {"Brand", "Type", "Store"}, {"Brand", "Type", "Store"})"All.Type", "All.Store"})Cheers!
- 3 years ago
PSB
Helper III
3 years agoamitchandak Could you please help resolving this either by DAX or Power Query?
- amitchandak3 years ago
