iKiok's avatar
iKiok
7 years ago
Power Query - (M code) - replace text in a column with values from a column in another query
Greetings to all,
I would like to replace many individual values in a column with values that exist in another query.
I cannot merge since I would like it to be a "text contains" replacement.
Any help with the correct "table[column]" reference to the other query would be appreciated
= Table.ReplaceValue(#"Renamed Columns",Replacements[original],(Replacements[replacement],Replacer.ReplaceText,{"Activity"})
    • iKiok's avatar
      iKiok
      Mariusz here is the data in 2 queries. Normally I would run 20 steps of "Replace Value", so now I am looking to make it happen a bit faster and easier
      Column where values need to be replacedReplacements Table
      • Mariusz's avatar
        Mariusz
        Hi iKiok,
        is there any chance you could prepare a sample of data that preserves the logic of your data and is easy to copy and work with?
        Many Thanks
        Mariusz
