Power Query - (M code) - replace text in a column with values from a column in another query
Mariusz here is the data in 2 queries. Normally I would run 20 steps of "Replace Value", so now I am looking to make it happen a bit faster and easier
Column where values need to be replacedReplacements Table
- Mariusz7 years ago
Hi iKiok,
is there any chance you could prepare a sample of data that preserves the logic of your data and is easy to copy and work with?Many Thanks
Mariusz
- iKiok7 years agoFrequent Visitor
so, Query Logs - Column Activity, normally i would run 17 steps to replace (text contains) text from Activity Column with other text.
now I have created another Table (Query - Replacements) and I would like to do the replacements with something like
= Table.ReplaceValue(#"Renamed Columns", each Replacements[original],each(Replacements[replacement],Replacer.ReplaceText,{"Activity"})
meaning that I would like to read the column from the other query and do the replacements in the Log query.
Is that possible (reading a column from another query)?
If yes, could you please help me with the syntax?
thank you in advance
