Balaaj_12's avatar
Balaaj_12
2 years ago
Power BI Visualization help
Hi all,
I am fairly new to Power BI and a convert from Tableau. I want to create a chart such as the one shown below with multiple Y axes and bar charts with different units. Is something like this possible on Power BI? Thanks!
  • Hi Balaaj_12
    You can create something similar with matrix and conditional formatting (bars) , but all the bars will have the same color on the column level like this :
    the pbix with the example is attached.
    The guide of using this kind of formatting is here :
    https://www.youtube.com/watch?v=9eVwlHXm7eM
    Note that I doubled measures of the columns to separate bars from numbers, to keep it accurate.
    If my answer was helpful please give me a Kudos and accept as a Solution.
    and if the red bars are because of some kind of allerts you can use red circle instead of coloring them.
    like I did here :
1 Reply
  • Hi Balaaj_12
    like I did here :
