Power BI Showing Blank Cells after Python Script
I've created a python script that takes in two different queries. When I run the script with extracts in visual studio the output is as desired, but when I run the script in power bi some of the rows have blanks in the last 3 columns. I've done some debugging and found that if I force the result as a string they come through as nan, but this still doesn't line up with the test output. My other thought was that the code that grabs those values was in correct, but then it wouldn't work for the ones that do work. I've also checked to see if there are any differences between the data that I'm pulling in and I cannot find any.
- Anonymous7 years ago
Figured it out. The table I was pulling data from had 264 columsn. Moved the columns I needed to the front and it pulled the data for all rows correctly. It's odd that it pulled some rows and not others, but now it works.
- AnonymousNot applicable
- daxCommunity Support
Hi rossData,
So it seems that you solve your issue, right? If so and if you'd like to, you could mark corresponding post as answer or share your solutions. That way, people who in this forum and have similar issue will benefit from it.
Thanks for your understanding and support.
Zoe ZhiIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
