Power BI Showing Blank Cells after Python Script
- Anonymous7 years ago
Figured it out. The table I was pulling data from had 264 columsn. Moved the columns I needed to the front and it pulled the data for all rows correctly. It's odd that it pulled some rows and not others, but now it works.
- dax7 years agoCommunity Support
Hi rossData,
So it seems that you solve your issue, right? If so and if you'd like to, you could mark corresponding post as answer or share your solutions. That way, people who in this forum and have similar issue will benefit from it.
Thanks for your understanding and support.
Zoe ZhiIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
