MariaFlorenciaB's avatar
7 years ago
Power BI features - visual help
Hi everyone! I was asked to include two changes in my Power BI dashboard but I am not sure if this is possible (I couldn´t find both features in power bi):
1) Is it possible to leave the first column of a table/matrix freezed? Like in an Excel table when you freeze a column, and when you move throw other columns you keep the first one visible.
2) Is it possible to add in a table/matrix a + to see more data if you want to? for example:
+ Food
and if you click the +:
+ Food
   Vegetables
   Fruits
Thanks!!!
  • Hi,
    I'm not sure about the first one.
    But the second is possible in a matrix.
    Just put the columns you want in rows to create a hierarchy and go into row headers options and enable:
  • Hi,
  • MariaFlorenciaB afaik, you cannot freeze but you can surely do +/-, go to format tab and turn it on
