mchiluka's avatar
mchiluka
4 years ago
Power BI data conversion issue
Hi All,
Not sure if I can explain in theory so I'm giving the screenshots of the issue
Source data:
After loading into Power BI:
By default if the values are same, it is taking the first coming format and getting applied to all others.
Is there a way I can avoid this? or is this the default feature.
Mahesh
  • Hi, mchiluka
    When you load data into Power BI Desktop, it will attempt to convert the data type of the source column into a data type that better supports more efficient storage, calculations, and data visualization.
    The engine that stores data in Power BI is case insensitive - which means the engine treats different capitalization of letters as the same value: a is equal to A. Power Query, however, is case sensitive: a is not equal to A. The difference in case sensitivity leads to situations where text data is loaded into Power BI and subsequently changes capitalization, seemingly inexplicably.
    This is the relevant document, hope to help you:
    https://docs.microsoft.com/power-bi/connect-data/desktop-data-types#text-type
  • Please let me know if better explanation of issue is needed. Need resolution urgently.
  • v-zhangti's avatar
    v-zhangti
    Hi, mchiluka
