Power BI data conversion issue
- 4 years ago
Hi, mchiluka
When you load data into Power BI Desktop, it will attempt to convert the data type of the source column into a data type that better supports more efficient storage, calculations, and data visualization.
The engine that stores data in Power BI is case insensitive - which means the engine treats different capitalization of letters as the same value: a is equal to A. Power Query, however, is case sensitive: a is not equal to A. The difference in case sensitivity leads to situations where text data is loaded into Power BI and subsequently changes capitalization, seemingly inexplicably.
This is the relevant document, hope to help you:
https://docs.microsoft.com/power-bi/connect-data/desktop-data-types#text-type
Hi, mchiluka
