Anonymous's avatar
2 years ago
Order visuals with text data using a index column
Hello   I'm working with some CRM data and I have to create a pipeline visualization. This means that I need to order a column that as text data like Negotiation, Proposal, Analysis and Commit.  ...
  • samratpbi's avatar
    2 years ago
    Hi, create a conditional column in Power Query with the corresponding numbers. Hence that sorting column would contain 1 when value is Qualification, 2 when Needs Analysis and so on. Once done, then sort by another column. When you click on your "pipeline_steps" column, at top Column tools would open. in Sort by column, choose that sorting column you created in Power Query.
    Now you may use pipeline_steps and it would be sorted.
    If this resolves your proble, then mark it as solution, thanks
