Need Help on splitting/combining values
I'm having a table of people, each with a value of how many projects they are working on. But the list contains duplicates when two people are working on it together, which is counted seperately.
Ex: There are 3 people a 10 total projects, here is how the list would look.
"Person 1" - 3 projects
"Person 2" - 2 Projects
"Person 3" - 2 Projects
"Person 1 / Person 2" - 2 Projects
"Person 2 / Person 3" - 1 Project
Is there a way to I can split or combine these values, or insert a delimeter of "/" to get a cleaner listing like this?
"Person 1" - 5 Projects
"Person 2" - 5 Projects
"Person 3" - 3 Projects
ok i think it is easy :
- goto query editor
- select "ASsigned Person" column
- under "Split Column" in menu, choose "By Delimiter"
- Choose semicolor delimiter
- Click Advaced option and select "rows"
- click ok
and this will do, so in you graph, now you will get the data what you are looking for
- drop person on x axis and project id on value (and choose count as summarization)
- parry2k
are quotes (") part of your data or it is just put in sample.
- Alex_BelfiglioNew Member
Just a sample to show that Person 1 / Person 2 is together.
- parry2k
can you share how your real data looks like?
Also do you always maximum 2 person like Person 1 / Person 2 or it can be more than 2 as well?
