Need Help on splitting/combining values
- 8 years ago
ok i think it is easy :
- goto query editor
- select "ASsigned Person" column
- under "Split Column" in menu, choose "By Delimiter"
- Choose semicolor delimiter
- Click Advaced option and select "rows"
- click ok
and this will do, so in you graph, now you will get the data what you are looking for
- drop person on x axis and project id on value (and choose count as summarization)
Just a sample to show that Person 1 / Person 2 is together.
can you share how your real data looks like?
Also do you always maximum 2 person like Person 1 / Person 2 or it can be more than 2 as well?
- parry2k8 years ago
this is what i produced from you data, assuming there / delimiter where more than 1 people working on a project.
- Alex_Belfiglio8 years agoNew Member
Sure, here is the table I'm working on in Direct Query.
Here are the charts that I'm trying to work with, with the top chart showing what I get, and the bottom filtered to show what I'm trying to make (with incorrect counts). But having trouble getting the values to correctly allocate to the individual persons.
- goto query editor
- click ok
Thanks, I think I'm getting slightly closer. I don't seem to have a "rows" option, this might due to not having the last couple updates.
It did split well into additional columns, I'm hopin to maybe add these together on my chart axis, but it looks like right now it is still filtering by the hierarchy.
