5 years agoNot applicable
Max per group using filter with DAX
Greetings, i have a table with 3 columns: date, machine and signal (there are lots of machines and signals and date is updated daily) Date Machine Signal 25/03/2021 x A 25/03/2021 x...
- Anonymous5 years ago
Hi Anonymous
Thanks for your answer, since i have lots of signals i have to use a matrix visual for the columns.
With your help i´ve managed to make a measure that returns exactly what i need, but i have to use two date slicers:
This is the measure i used:
MaxPC =var fecfin = MAX(Fecha[Date])var fecini = CALCULATE(MAX(table[date]),ALLEXCEPT(table,table[equip],table[signal],table[date]))returnDATEDIFF(fecini,fecfin,DAY)
Hi Anonymous
Do you have a Date table with relationship to this table? I have one, the slicer coming from date column from this Date table
test =
VAR CurDate = SELECTEDVALUE('Date'[Date])
VAR LDate = COALESCE(MAXX(FILTER(yourTable,yourTable[Date]<=CurDate),yourTable[Date]),CurDate)
DATEDIFF(LDate,CurDate,DAY)
Hi Anonymous
MaxPC =
return
