Matrix Timetable - Power BI solution
- 6 years ago
Hello @Lachsforelle12 ,
Taking into account the need you have, I have taken the following steps:
Milestones = VAR end_date = CALCULATE ( CONCATENATEX ( FILTER ( 'Table'; 'Table'[EndDate] <= MAX ( 'calendar'[Date] ) && 'Table'[EndDate] <> BLANK () ); 'Table'[Milestone]; UNICHAR ( 10 ) ); USERELATIONSHIP ( 'calendar'[Date]; 'Table'[EndDate] ) ) VAR start_date = CONCATENATEX ( FILTER ( 'Table'; 'Table'[Date] <= MAX ( 'calendar'[Date] ) ); 'Table'[Milestone]; UNICHAR ( 10 ) ) RETURN SWITCH ( TRUE (); start_date = BLANK () && end_date = BLANK (); "0"; end_date = BLANK (); start_date; end_date & UNICHAR ( 10 ) & start_date ) Formatting = SWITCH ( TRUE (); EOMONTH ( MAX ( 'calendar'[Date] ); 0 ) = EOMONTH ( TODAY(); 0 ) && [Milestones] = "0"; 2; EOMONTH ( MAX ( 'calendar'[Date] ); 0 ) = EOMONTH ( TODAY(); 0 ); 1; [Milestones] = "0"; 0 )You must also create an inactive relationship between the calendar and the end date.
Now configure your condittional format according to this:
Check Attach File.
In terms of formatting things can be done in a different way depending on the way you need to do things, but you have the general idea.
Thank you. @MFelix
He needs other advice.
I have 6 milestones for each project (1.A, 2.B, 3.C, 4.D, 5.E, 6.F) and a start date and an end date.
How can I apply your proposal to my data?
My calendar table is in the main table. This was created with the "Calendaauto" function.
this is what it should look like (both tables are connected by an index)
Hi Anonymous ,
There area couple of things that I'm missing:
- Why is your calendar table with repeated values? (this ttype of tables should only have unique values)
- Do you want to show the start and end date of the milestones on the visualization?
- Assuming you don't have milesotnes overlapsed
- If you only want one what is the one to be presented star or finish?
- How do you know it's the current one?
- When milestone are finish they stay with the same date for beggining and ending?
- Does your relationship between the calendar date how is it done by date?
https://www.youtube.com/watch?v=SO4mk1H94OA
--> That was my inspiration to build a Gantt in a year or a month's view
- Why does the calendar table have repeated values? (this table ttype should only have unique values)
--> have created a new date table with unique values (Period 2019 to 2030)
- Do you want to display the start and end date of milestones in the visualization?
--> Yes, I want to see the start and end date if possible.
- Assuming you don't have miles overlaid
--> milestones can overlap... is this generally not possible?
- If you only want one, which one is presented star or finished?
- When does the milestone end do you get the same date for the beginning and end?
- How is your relationship between the calendar date by date?
--> it is not important to know what the current MEilenstein is.
It is only important to see as a kind of summary of when the milestone is planned (start date).It would also be nice to see when a milestone has been reached. It's supposed to be some kind of Gantt chart.
In addition, it would be nice to see what the current month is, as described at the beginning.
- MFelix6 years ago
Check Attach File.
